Audiophonics DAC Sabre ES9023 i2s 24bit/192 - Raspberry Pi
Re: Audiophonics DAC Sabre ES9023 i2s 24bit/192 - Raspberry
Postby spikey1973 » 23 Jan 2016, 20:44
oke i really don't understand what happend here but while i was checking the stuff out you asked for and about it suddenly started to work.
t appeared in the list and the wheel (of fortune) spun and there was the entire list.
but the auto mount was already on and the debug info i couldn't find still not.. but it works.
hapy about that it works but not happy that i don't understand why, now i still wouldn't know what to fix would it happen again.
but anyway that's it and now i'll go and work on my box for the RPI. incl drive and battery. :D
thanks for your help!
spikey1973
Postby otec » 03 Feb 2016, 23:04
I would to say big thank you to creators of RuneAudio and people from this thread to explain how setup Audiophonics DAC. It works like a charm !
Although, I have couple of questions regarding the ES9023 board:
1. There is 5V power outlet on it. Is it worth connecting a separate power there or is the power that it gets via I2S is enough ?
Will this improve sound quality ?
2. My ES9023 is v2 and apparently has TXCO clock. Is it worth driving it off a different clock ?
otec
Postby otec » 03 Feb 2016, 23:52
One more question,
does hardware volume control work with HiFiBerry DAC ?
I can select it in MPD settings, but then I cant change volume in Web UI, even if I put 0, the sound volume remains the same.
otec
Postby ACX » 04 Feb 2016, 01:35
Postby otec » 04 Feb 2016, 12:40
otec
Postby otec » 05 Feb 2016, 01:46
Tried enabling HiFiBerry DAC+ driver in config.txt and upon reboot I couldnt select device in MPD list and there were some errors in dmesg.
I guess it doesnt work.
otec
Postby guillaumesej » 20 Apr 2016, 16:35
guillaumesej
Postby hondagx35 » 20 Apr 2016, 20:18
Postby knottydreadbr » 11 Aug 2016, 18:23
knottydreadbr
Postby cesarus » 21 Dec 2016, 13:52
I am new on this forum so Hello !
Dose any one now can this DAC work on RPi 3 b http://www.ebay.com/urw/write-review/14 ... 1572582020.
I tried to connect but without sucess.
cesarus
Return to Compatibility list
