Audiophonics DAC Sabre ES9023 v3
Postby snake » 15 May 2016, 18:15
I can't get this DAC to play anything. I have followed steps found on this forum and have enabled in /boot/config.txt
dtoverlay=hifiberry-dac
The only thing I can see as a problem is inside dmesg output after boot:
[ 7.518507] snd-hifiberry-dac sound: ASoC: CPU DAI (null) not registered
[ 7.518535] snd-hifiberry-dac sound: snd_soc_register_card() failed: -517
[ 7.521017] snd-hifiberry-dac sound: ASoC: CODEC DAI pcm5102a-hifi not registered
[ 7.521049] snd-hifiberry-dac sound: snd_soc_register_card() failed: -517
[ 7.527096] snd-hifiberry-dac sound: pcm5102a-hifi <-> 3f203000.i2s mapping ok
Not sure how important this is.
Can anyone help out ?
snake
Re: Audiophonics DAC Sabre ES9023 v3
Postby hondagx35 » 15 May 2016, 21:51
Hi snake,
after enabling the DAC in /boot/config.txt you have also to select it as output device (MENU->MPD).
Please post your complete debug info.
Postby snake » 16 May 2016, 07:39
Hello Frank,
Yes, I have changed mpd output device.
Here is debug info from the system.
http://pastebin.com/yYc8p27J
snake
Postby rikardo1979 » 16 May 2016, 10:11
we have an extended thread about this already ;) audiophonics-i-sabre-v3-dac-es9023-tcxo-t3377.html so you may read over there
And maybe merge this into it?
rikardo1979
Postby snake » 17 May 2016, 07:48
This thread does not seem relevant for my problem. Frank, have you had a chance to go through my debug data ?
snake
Postby rikardo1979 » 17 May 2016, 08:29
rikardo1979
Postby hondagx35 » 17 May 2016, 12:09
Hi snake,
please turn off hardware volume, because this DAC doesn't allow this.
Postby snake » 17 May 2016, 18:52
Hello Frank,
I have tried your suggestion:
1. set volume control to disabled, play = no sound
2. reboot, play = no sound
3. set volume control to software, set volume to 100, play = no sound
4. reboot, play = no sound
My amplifier works fine when something else is connected to the same set of cables.
Am I having a hardware problem ?
snake
Postby PeteB » 18 May 2016, 03:19
Have you tried selecting the analog port on the Pi as output? Not as solution, but to exclude other unrelated hardware issues... I mean, there could be a lot of reasons if you are down to looking at hdw!
Postby snake » 18 May 2016, 08:52
I have tried playing through HDMI out and it worked well.
snake
Return to Compatibility list
