AudioPhonics DAC
AudioPhonics DAC
Postby sylvain » 08 Sep 2015, 20:18
Hi there,
I have 2 Rune devices : one old PI B+ with a IqAudio DAC, and a brand new Pi 2 running an Audiophonics DAC SABRE 9023.
I made some tests, and was very surprised to notice that running the Sabre on the PI2 was bad ! The sound is really much better on the B+. I ran a lot of test, and i'm pretty sure that's a software issue. The sound is much more punchy, louder, really better on the old Raspberry device.
Is there something to do, or should i wait for the next RuneAudio ?
Thanks to the dev anyway for this awesome software !
sylvain
Re: AudioPhonics DAC
Postby hondagx35 » 08 Sep 2015, 22:02
Postby sylvain » 09 Sep 2015, 05:02
I also swap the DACs between the 2 rasp.
Sent from my iPhone using Tapatalk
sylvain
Postby Aquarius » 09 Sep 2015, 12:29
Might not be only a software issue.
The Pi 2 no longer has linear regulators but switching devices .
It's like if the Raspi is supplied by a class A/B power supply, but the Pi 2 is supplied by a class D pwoer supply. This is really much more efficient for power consumption (more than 1W gained, they said) but might affect how your DAC is supplied.
Also try to switch the power brick, too.
-- Aquarius
Aquarius
Postby sylvain » 09 Sep 2015, 12:54
Interesting! I tried with different power supply, but it did not help...
sylvain
Postby Corallaro » 22 Sep 2015, 09:14
Hi Sylvain
I have similar issue with my I2S HIFI DAC es9023
http://www.ebay.it/itm/181694631154?_tr ... EBIDX%3AIT
after reading your post i made a simply test:
With my RASPI 2 i hear irregular noises over the "white noise" of ampli (play a song, press stop, then put ampli to max volume)
(this with Rune audio, volumio and openelec)
with same hardware (alimentation, ampli etc etc) with my RASPI B+ i hear only the "white noise" of ampli.
(this with Rune audio, instead openelec make the same noise!)
At this point i use rune audio and update it via git to read cue files
Best regards
Giovanni
Corallaro
