[HELP] AUDIOPHONICS I-Sabre V3 DAC ES9023 TCXO
Re: [HELP] AUDIOPHONICS I-Sabre V3 DAC ES9023 TCXO
Postby rikardo1979 » 10 Apr 2016, 23:01
rikardo1979
Postby rikardo1979 » 10 Apr 2016, 23:02
rikardo1979
Postby rikardo1979 » 10 Apr 2016, 23:16
btw, its going to be more fun than I thought[irony]
My experience with Arch is zero...
I did not realized is so different
OP2
rikardo1979
Postby rikardo1979 » 11 Apr 2016, 18:05
rikardo1979
Postby PeteB » 11 Apr 2016, 18:27
Hi Ricardo,
Do you have a wiring diagram or a list of wires and connections to pins for the button? I ask because I see you moving the wires in the video, and as far as I can tell from the Audiophonics web site, there should just be two wires for the LED (+ and -), and two wires for the switch contact, NO (normally closed) and NC (normally open). So you should not have to try different connections (?)
P.
Postby rikardo1979 » 11 Apr 2016, 20:04
rikardo1979
Postby ingohz » 11 Apr 2016, 20:23
+/- for the LED are clearly labeled and the button should be connected to the 3 pins named "C" (common), "NO" (normally open) and "NC" (normally closed). As it is a 2-pole switch there are 2 of each and you have to use one row of them. Maybe you can test it with a multimeter. Keep away from the LED-pins and test if the contact is shortened between the "C"- and "NO"-pin if you press the button.
ingohz
Postby PeteB » 11 Apr 2016, 21:15
The letters will be on the plastic end by the pins. There is more than one contact, from the pic probably two contacts, each with C/common, NO/normally open, and NC normally closed contact.
From the description you only need one of the two, so some pins will be unconnected. So it looks like you need 4 wires, two for the LED + and -, and two for the switch.
Either side of the switch, should work, and only the "C" and "NO" contacts are used.
Postby hondagx35 » 11 Apr 2016, 21:41
Postby rikardo1979 » 11 Apr 2016, 22:16
rikardo1979
