[HELP] AUDIOPHONICS I-Sabre V3 DAC ES9023 TCXO
Re: [HELP] AUDIOPHONICS I-Sabre V3 DAC ES9023 TCXO
Postby hondagx35 » 13 Apr 2016, 19:54
Postby hondagx35 » 13 Apr 2016, 21:48
16x2_oled_runeaudio.tar.gz
(2.09 KiB) Downloaded 1116 times
Postby nicko500 » 13 Apr 2016, 22:22
nicko500
Postby rikardo1979 » 14 Apr 2016, 06:23
rikardo1979
Postby rikardo1979 » 14 Apr 2016, 07:13
and I have another question.
Is it possible to deactivate all the volume controls so I have the best audio quality output?
As when I select this in GUI settings and go back to home screen is still works. But I did not try reboot after settings changed, would that make any difference?
rikardo1979
Postby All4linux » 14 Apr 2016, 08:31
Hi Rikardo,
Yes it's possible. Go to MPD tab in Menu and disable the option volume control. I suggest you to desactivate FFMPEG decoder plugin and volume normalization.
Best regards !
All4linux
Postby thedman! » 14 Apr 2016, 18:56
The postman arrived.... a day late :x however I've forgiven him now...
I followed the scripts and indeed rune seems to shutdown when I press the button. However it won't turn back on and the screen is clearly on, is this supposed to be the case?
I was expecting that when the button is pressed for pi to go into some sort of really low power state and turn the screen off and when it is pressed again, for the screen to turn on and rune to start up.
If the above sentence is supposed to happen I have an idea why, but I'm not saying so I don't appear to be COMPLETELY stupid...
Thanks again for your help,
Dave.
thedman!
Postby rikardo1979 » 14 Apr 2016, 19:02
rikardo1979
Postby thedman! » 14 Apr 2016, 19:04
Sorry, I have probably hijacked this thread a couple of times... I'll start a new thread....
thedman!
Postby rikardo1979 » 14 Apr 2016, 19:44
rikardo1979
