[HELP] AUDIOPHONICS I-Sabre V3 DAC ES9023 TCXO
Re: [HELP] AUDIOPHONICS I-Sabre V3 DAC ES9023 TCXO
Postby Baldgreene » 18 Apr 2016, 20:39
If this may help someone in debugging its startup/shutdown scripts, here is the led sequences for a fully functional Sabre V3+power button setup on a RPI 3, using the scripts described in audiophonics-i-es9023-sabre-dac-v3-tcxo-raspberry-pi-2-0-a-t3277.html#p12548 (but Frank scripts given in the present thread should work as well, if not better)
Hardware start (power button)
- the white led of the power button blinks slowly (~1 s) + the red led on the RPI board turns on steadily,
- the blue led the Sabre board turns on in a steady manner,
- the white led on the power button becomes steady.
Hardware stop (power button pressed for more than 0.2 s and less than 4 s)
- the white led of the power button starts blinking slowly (~1 s) + the red led of the Sabre board turns on steadily (in addition to the steady blue led being on since the startup),
- the blue & red leds on the sabre board turn off,
- the white led on the power button and red led on the RPI board turn off.
Software stop (Rune GUI "Power off")
- the white led of the power button starts blinking fast (~0.5 s),
- the blue led on the Sabre board of turns off,
Software reset (Rune GUI "Reboot")
- the white led of the power button starts blinking very fast (~0.25 s),
- the blue led on the Sabre board turns off,
- the red led on the RPI board remains on,
- the blue light on the Sabre board turns on,
- the white led of the power button becomes steady.
Note that in every sequence the green led of the RPI board is turning on and off "randomly" once the red led of the RPI board is on, denoting read/write on the SD card.
Regards,
Lionel
Baldgreene
Postby rikardo1979 » 21 Apr 2016, 20:57
rikardo1979
Postby rikardo1979 » 22 Apr 2016, 16:28
Thanks to @Bruno.dualo for great simple HowTo guide and thanks to @Frank for updated python script for V3 board
So all is working perfectly now. Power button and OLED screen, everything.
Actually it works better than what Audiophonics have done with Volumio.
With runeaudio and this I have all the track information from Tidal streams displayed correctly :)
Happy days
edit: here is the python scrip for V3 DAC
16x2_oled_runeaudio.py.tar.gz
(2.1 KiB) Downloaded 845 times
rikardo1979
Postby PeteB » 22 Apr 2016, 16:58
Happy to hear you got it all working! I am glad you persevered through this endless thread, LOL..
Postby rikardo1979 » 22 Apr 2016, 17:05
rikardo1979
Postby ingohz » 22 Apr 2016, 17:36
ingohz
Postby PeteB » 22 Apr 2016, 17:54
Postby rikardo1979 » 22 Apr 2016, 17:59
rikardo1979
Postby PeteB » 22 Apr 2016, 18:08
Postby rikardo1979 » 22 Apr 2016, 18:12
rikardo1979
