[SOLVED] Auto Play Music
Re: Auto Play Music
Postby mikeoh » 15 Apr 2015, 16:03
mikeoh
Re: Auto Play Music
Postby liddle1992 » 10 Feb 2016, 22:14
liddle1992
Auto Play Music
Postby meandnobodyelse » 26 Feb 2017, 19:12
@wimpie007:
the problem is sitting in rune_SY_wrk (RuneOs: 0.3-beta, RuneUI: 1.3-beta, Hw-env: RaspberryPi 2).
after the line 286 the main loop starts but the local storage (usb) ist still not properly mounted.
a 'mpc play' throws an 'error no such file here as your playlist-file'.
so a:
sysCmdAsync('/var/www/command/refresh_nics ; /var/www/command/debug_collector');
$mount='';
while (!$mount){
sleep(1);
$mount=implode('',glob('/mnt/MPD/USB/<your volume name comes here>/*'));
`/usr/bin/mpc play`;
runelog('WORKER MAIN LOOP ---');
does the trick for now. but it's still rather very dirty.
A nice 'start playing on boot' option in the UI would be much better, of course.
meandnobodyelse
Re: [SOLVED] Auto Play Music
Postby SteveberryPi » 27 Feb 2017, 16:09
Ok..
Reading this post..
Dose this edit make the RuneAudio play Automatically when start up...
Im looking at useing the RuneTune on a Pi for a in store music stream and when the power goes out i would like the Pi to start back up Automatically and play a internet stream or if it dose not connect to the stream it will play a playlist is this possible with the above code ?
SteveberryPi
Users browsing this forum: No registered users and 34 guests
