B&W Zeppelin AIr as USB DAC
Postby tmilovan » 23 Apr 2016, 11:32
I'm trying to use B&W Zeppelin Air over USB as DAC and speaker and all works fine except I cannot use software volume control nor can I control the volume with external Zeppelin's volume control. The only way I can affect volume is via alsamixer and even there only PCM control is available.
Is there anything I can configure so I get a little more control over Zeppelin Air unit?
Thanks.
tmilovan
Re: B&W Zeppelin AIr as USB DAC
Postby hondagx35 » 23 Apr 2016, 11:58
please post your debug info.
how-to-collect-debug-info-t431.html
Postby tmilovan » 23 Apr 2016, 18:55
Here it is:
http://pastebin.com/UqkUivve
Thank you.
tmilovan
Postby hondagx35 » 23 Apr 2016, 21:38
Postby tmilovan » 24 Apr 2016, 12:08
Ah sorry it must have switched card back to default while I was turning Zeppelin off and on again. Here is the correct debug output: http://pastebin.com/SRbVHXyk
Also, I have found out that volume does not work only when streaming Spotify. With everything else it works fine.
And thanks for the rest of the tips:) I'll try the new image as soon as I manage some time to write it to sd card.
Thank you.
tmilovan
Postby hondagx35 » 24 Apr 2016, 12:45
Postby tmilovan » 24 Apr 2016, 13:21
Ah, I see. Thank you,
tmilovan
Return to Hi-Fi systems
