BerryNOS DAC module for RPi
Re: BerryNOS DAC module for RPi
Postby tc-fi » 04 Mar 2014, 16:13
tc-fi
Postby tc-fi » 05 Mar 2014, 15:52
tc-fi
Postby ACX » 05 Mar 2014, 16:34
The current 0.2-beta version does not have I2S support out of the box, the incoming 0.3-beta will do.
Postby Midnight » 06 Mar 2014, 10:04
Midnight
Moderator
Postby tc-fi » 10 Mar 2014, 15:10
What is architecture of TDA1543 (R2R, other)?
tc-fi
Postby eragefe » 12 Mar 2014, 00:42
It is a multi bit and not a R2R DAC.
BR G
eragefe
Postby tc-fi » 12 Mar 2014, 02:45
Yes, it's PCM multi-bit (as opposed to Sigma-Delta multi-bit), but what I would be interesting in knowing is what approach (architecture) is used to convert the bits into voltage.
Looking at the datasheet, the block diagram suggests some type of binary-weighted design.
tc-fi
Postby eragefe » 12 Mar 2014, 12:51
On that card we are using a passive IV stage.
BR G
eragefe
Postby tc-fi » 12 Mar 2014, 15:25
Nice!
But on-chip, referencing the block diagram, there is separate passive divider for MSB and LSB suggesting that this is some sort of binary-weighted design.
Correct?
tc-fi
Postby metalrob » 11 Jul 2014, 17:58
Hi!
I intend to connect BerryNos DAC to cubietruck via I2S. Is that easy to handle?
Greetingz
metalrob
