Best re-sample quality in MPD/Alsa
ODROID related support
Postby otec » 27 Mar 2016, 11:57
otec
Re: Best re-sample quality in MPD/Alsa
Postby silvrr » 11 Apr 2016, 01:24
Why are you re-sampling MP3s to 32/192? There is no reason for up sampling your music.
silvrr
Postby otec » 11 Apr 2016, 11:27
Yes there is, it sounds much better.
Sent from my Nexus 6P using Tapatalk
otec
Postby hondagx35 » 11 Apr 2016, 21:58
Postby ACX » 12 Apr 2016, 02:27
The only good reason for upsampling your source is when you use a DAC which works with automatic upsampling (i.e. 24/192), but the resampling hardware is poorly implemented. Only in this case it's preferable to leave that operation to the software, otherwise it's a waste of CPU and you are possibly degrading the signal with the resampling.
Postby otec » 15 Apr 2016, 09:56
I run DAC that supports such freq. so hence I'm doing this.
otec
Return to ODROID
