Best workaround for 24 Bit playback on Cubietruck
Cubietruck related support
Postby floyd » 06 Feb 2016, 06:54
Hi Guys,
whats the best work around, do you think, for being able to play all my 24bit files that are in my library through cubietrucks optical out?
I can play them via the 3.5mm output and the quality sounds better than I was expecting, but I do prefer the DAC in my Sony amp.
Is there a downsampling option in Rune?
floyd
Re: Best workaround for 24 Bit playback on Cubietruck
Postby hondagx35 » 06 Feb 2016, 11:05
Postby floyd » 06 Feb 2016, 22:45
Gday Frank,
Thanks for the reply mate.
Sorry, Ive made a boo-boo....
This amp/receiver (Sony STR-DB940) is new to me, as my (not-so) trusty Onkyo decided to stop outputting audio.
Anyways, Ive just done some more reading and the issue is my amp, not the cubietruck (although I am surprised to learn that is has no drama outputting 24/192 via spdif, as most sources say it is limited due to hardware, although technically possible)
Turns out my amps DAC can not handle 192 sample rates. Maxes out at 96. But 24 bit is no problem....so Ill have to downsample my 192 files. Bummer. But at least I can play all my other 24 bitters.
floyd
Postby rune11 » 15 Dec 2017, 19:22
rune11
Postby siyaberger » 24 Dec 2019, 10:24
Thank you so much dear
siyaberger
Postby rlugli » 08 May 2020, 08:35
rlugli
Postby samevans » 12 Jan 2024, 04:15
The main two are to be able to go to the best upsampling algorithm (src-sinc-best-quality) and to go to higher sampling rates (192kHz, 384kHz?).
samevans
Return to Cubietruck
