Bluetooth headphone support (and mod guide)
Postby leveller » 25 May 2017, 04:26
leveller
Re: Bluetooth headphone support (and mod guide)
Postby ccomred » 02 Mar 2018, 13:45
Hi, I have Problems to compile bluez-alsa.
[root@runeaudio ~]# cd bluez-alsa/build/
[root@runeaudio build]# ../configure --enable-aac --enable-debug
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking for gcc... gcc
checking whether the C compiler works... no
configure: error: in `/root/bluez-alsa/build':
configure: error: C compiler cannot create executables
See `config.log' for more details
ccomred
Postby janui » 02 Mar 2018, 22:41
Postby tuna » 18 Aug 2018, 07:49
Did you ever find a solution to GCC not being able to compile?
tuna
Postby Toube » 20 Oct 2018, 09:26
So this would also enable you to stream music from your mobile phones local storage using Bluetooth connection to Rpi?
Would definitely be a good feature to be able to stream music from you mobile phone directly to your rpi?
-Toube
Toube
Postby Toube » 20 Oct 2018, 11:56
Looks like they found a way to get it working in volumio
https://volumio.org/forum/volumio-bluet ... t8937.html
Toube
Postby janui » 20 Oct 2018, 21:13
Hi all,
Rune v5b has all the components which are required for Bluetooth pre-installed, the services are disabled. During the build of 0.5b Gearhead solved the problems relating to building these packages. I have not had time to fully test all the components on armv6 and armv7, but simple connections of a Bluetooth keyboard and mouse have worked on the armv6 version. If you don’t use Rune v5b you can download the arch package set as a zip file using the link: http://www.mediafire.com/file/4yg6zpvth ... h.zip/file (SHA256: 41A18BF401A71B565ED06FBA4E2532C1F0FAE07AF621AC7E2BAAE365A86B50FD).
Postby Toube » 21 Oct 2018, 08:24
Toube
