Bubble upnp
Bubble upnp
Postby BorGreiner » 24 Sep 2015, 06:23
Does anyone use Raspberry Pi with BubbleUPnP app (with bublleupnp server setup at PC - http://www.bubblesoftapps.com/bubbleupnpserver/)?
It sounds complicated, but I found this to be the best workarround to use my Tidal account with rune audio.
When it works, it works brilliantly.
However... I am having timeout issues (BubbleUPnP app error: Action timeout) when using it and it is extremely annoying. Does anyone experience this as well? It there any solution to this?
BorGreiner
Re: Bubble upnp
Postby Aquarius » 24 Sep 2015, 08:28
Bubble UPNP works fine in my setup. Access to my Twonky DLNA server on the NAS to stream to RuneAudio or to stream to my hifi Streamer. So it's the phone who really does the streaming. No BubbleUPNP server in my case.
Bubble UPNP also has access to my Qobuz purchases which is really great. (and if I ever subscrive to the 10€/month tier of Qobuz, I will have access to their full catalog as well).
No issues on my side except sometimes the app on the phone dies, but it doesn't happen often. And of course, if I forgot that I lunched some playlist via streaming, walk out of wifi range with the phone in my pocket, then the music stops.
-- Aquarius
Aquarius
Re: Bubble upnp
Postby psychofaktory » 25 Sep 2015, 14:13
psychofaktory
Re: Bubble upnp
Postby BorGreiner » 27 Sep 2015, 15:11
I have found a solution for "timeout issuses" when controlin RuneAudio with BubbleUPnP server from BubbleUPnP app on Android.
You have to set BubbleUPnP server (in my case on Windows 10) to "Create an OpenHome renderer". Voila! :)
BorGreiner
Re: Bubble upnp
Postby yael44 » 14 Nov 2015, 14:57
Hi, i have just put RuneAudio on my raspberry, it works well with the web radios and i can open runaudiolocal on my macbook, which was not possible with volumio (impossible to open volumiolocal on any browser). I have an account at qobuz (i'm french). I have a galaxy s5 with bubbleupnp which could see very well volumio, but doesn't see RunAudio. Any suggestions? Thanks you in advance.. i don't know how to listen to qobuz through the raspberry.
cheers,
y
###### System info ######
Linux version 3.12.26-1-ARCH (nobody@root-armv6-copy) (gcc version 4.8.2 20131219 (prerelease) (GCC) ) #1 PREEMPT Fri Aug 8 17:40:14 MDT 2014
system time: Sat Nov 14 14:42:07 CET 2015
system load: 0.42 0.30 0.25 2/86 777
HW platform: RaspberryPi (01)
playerID: 01ce22edff80022f9116a029273a35ec69
yael44
Re: Bubble upnp
Postby hondagx35 » 14 Nov 2015, 15:23
Hi yael44,
is UPnP enabled on the settings page (MENU->Settings)?
Re: Bubble upnp
Postby radley112 » 14 Apr 2022, 11:26
TIDAL already knows about RuneAudio. I contacted them via their facebook page and they replied to me "Hi Tuomas. Thank you for sharing this. We will share it directly to our Partner Team. Best, TIDAL.". I guess that one of the biggest questions would be that how many would subscribe to TIDAL if it worked on Rune.
radley112
Re: Bubble upnp
Postby jordanlaris » 18 Oct 2022, 03:30
It's fine, I'm Using the Raspberry Pi as a DLNA receiver for a stereo system
jordanlaris
Re: Bubble upnp
Postby jennytrippi » 18 Oct 2022, 05:14
Once set up, Bubble UPNP works fine. I found that Bubble UPNP also has access to Qobuz purchases, a bit surprising but also good
jennytrippi
Users browsing this forum: Bing [Bot] and 26 guests
