Bug report 0.4 beta
Bug report 0.4 beta
Postby morgengut » 11 May 2017, 08:04
the last days I had the time to setup my Raspberry 2 with a Wingoneer Digi card. All hardware is fully supported, including remote control of my Onkyo TX-RZ900. Now I'd like to report some bugs of the rune audio player.
1. Library view: Setup button for library home screen does not work
2. Library view: If you choose any tag button like Album, Artist, Genre and you play a track directly from the library, the back button returns to the home screen. If you don't play a track the button back works fine.
3. Library view: If you choose any tag button like Album, Artist, Genre and you choose Add, Replace and Play the queue is not cleared. The tracks are all merged to the current playlist. It works fine in USB storage view.
4. Replay gain in MPD settings does not work. After setting to ON and saving it turns back to OFF.
5. Library view: In genre the database points on some items to the wrong tracks. Database rebuild doen't fixes the problem.
At last I want to congratulate to a nice player. In contrast to Volumio it is very helpful that the connection between mpd playlist and queue is still granted. I hope my list can help you to improve your player.
Best regards
us
PS: I'm using the rune player version 0.4 beta (date 21.03.2016)
morgengut
Re: Bug report 0.4 beta
Postby hondagx35 » 11 May 2017, 11:16
Postby morgengut » 11 May 2017, 17:44
thank you for the link to the actual beta. I've tested my points so far.
Item 1: Button not working
Item 2: Fixed
Item 3: Fixed
Item 4: Now set correctly in MPD, but not working at all. Please check. I'm not really sure.
Item 5: Fixed
For completion of my items:
Lyrics are only triggered by starting the gui, should be triggered by changing the track in the playlist
Samba is not working out of the box, you have to start it via ssh
Nice:
Webradio entries are sorted in alphabetical order now
New tab "composer" is very helpful for classical music
Thank you very much, well done.
us
PS: Comment is related to beta 0.4 (29.02.2017)
morgengut
Postby hondagx35 » 12 May 2017, 10:21
Postby morgengut » 12 May 2017, 11:23
thank you for your reply. Unfortunally I'm not very familiar with replay gain, can you tell me what to do tagging my music library?
Cu us
morgengut
Postby hondagx35 » 12 May 2017, 11:34
(german)
(german)
Postby morgengut » 13 May 2017, 10:06
replaygain is now working. Thanks for your support.
Cu us
morgengut
