Bugs with CUE & others
Postby ersau » 27 Oct 2015, 16:48
I previously use Raspyfi who worked very fine for me but do not allow to use the cue files and a picobber I2s DAC which now works fine with Hifiberry kernel module.
I listen a lot of classical music and dont want to cut a concerto in 3 files. So cue support is very important for me. I just have to reencode all the ape in flac and adapt the cue files but losseless to losseless is not a big problem.
I use the nighty build version (to try Drible) and find some bugs :
1/Playlist : I can create a queue with a selection of cue files. When i save a such playlist and reopen it, only the .flac files are shown.
2/Library : The ADD... functions on a folder don't use the cue files. A music player usualy take the cue file if it has the same name as the corresponding musical file
3/Library : Empty Folders, or with shortcuts (generaly with no music files) are not alphabeticaly sorted and are at the end of the list.
4/Source Menu : a usb stick removed cannot be deleted via menu (i found a manual roundabout on the forum)
Add of functionality :
if possible to add a function to play a queue in random order (i have seen a such request in the forum).
Good job and i hope soon a major version
ersau
Users browsing this forum: Majestic-12 [Bot] and 64 guests
