Build MPD library from NFS share
Postby perryni » 05 Mar 2016, 16:47
I have just added an NFS share (WHS2011) and RuneAudio has put a green tick by it so I presume all is ok but when I try to build the MPD library nothing happens.
Am I missing something?
perryni
Re: Build MPD library from NFS share
Postby surfninja » 07 Mar 2016, 17:20
Perry, go to 'Library' -> 'Network Mounts' and click on your mount. See if any of your files are there. If not, select the mount, click on the actions icon on the far right (three horizontal bars). Select 'Update this folder'.
This will also rebuild the library.
If you don't see any files, your mount point may be wrong or you don't have read access to the files.
If you do see files but no sound when playing (playback tab, left 'circle' is moving/counting, right volume 'circle' is at something like 80), this is a different issue. Try headphones to verify sound.
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Postby rhodo » 07 Mar 2016, 21:22
The solution beneath by Hondagx35 quoted from another thread did the trick for me:
______________________________________________________________________________
Hi ,
in most cases this is a permission problem.
Mpd runs as user mpd, using ssh you root.
You can try to modify the settings on your windows machine or change the Daemon user : group.
See Menue->MPD->Daemon user : group
_______________________________________________________________________________
rhodo
