Can I stream Tidal on Runeaudio?
Postby cranaing » 05 Feb 2020, 17:30
I'd like to stream Tidal to my living room amplifier. Would I be able to to that with Runeaudio?
I wasn't able to yield any answer while searching.
cranaing
Re: Can I stream Tidal on Runeaudio?
Postby rastus » 05 Feb 2020, 22:24
rastus
Postby cranaing » 06 Feb 2020, 22:05
cranaing
Postby rastus » 06 Feb 2020, 23:00
rastus
Postby vennesch » 29 Mar 2020, 13:51
I've got the same question, any real solutions?
vennesch
Postby bnilsson » 30 Mar 2020, 13:01
I use BubbleUPnP for Android with my Qobuz account and use RuneAudio as a DLNA render device.
It works extremely well.
BubbleUPnP also has Tidal support, which I have never tried since I do not have a Tidal account, but I have no reason to believe it should not work as well.
I can seriously recommend a try.
BN
bnilsson
Postby vennesch » 30 Mar 2020, 15:21
Thanks for your answer. Do you get meta data of the songs that are playing? I use Tidal with BubbleUpNP but only see the song name, not the artist nor the cover.
vennesch
Postby philauss » 11 Nov 2021, 13:25
philauss
Postby johngouk » 31 Jan 2022, 19:04
You can, but you will need a suitable control point, like Linn Kazoo or Android BubbleUPnP. Check out the info on the current BubbleUPnP Server version (https://bubblesoftapps.com/bubbleupnpse ... gelog.html), which now supports the OAuth protocol that Tidal requires. Basically, you need to get the BubbleUPnP Server logged in via BubbleUPnP on Android, then you can log in on whatever UPnP control point software you want to use. Fiddly, but it works. Unless the Rune people want to go through the grief of getting this to work native for Rune, that's it. Personally, I use a control point which allows me to select/control any of my Rune players, which all refer to the same media server and bubbleupnp server.
johngouk
Postby philauss » 01 Feb 2022, 10:00
philauss
Users browsing this forum: No registered users and 73 guests
