Can not make MPD rebuild library
Re: Can not make MPD rebuild library
Postby surfninja » 28 Oct 2016, 02:07
John, If you see the mount point on the 'Library' screen look like the attached and you can't click on the Network mounts and view your HD, you probably have a permissions problem. I'd suggest you set the user/name password when you mount the file system. I had to set the username/password to my mount point working.
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Postby johnberg » 29 Oct 2016, 10:37
Is somebody there to help me???
My hard drive is mounted and recognized as /dev/sda1 USB/ELEMENTS.
When I click "REBUILD MPD LIBRARY" the spinning wheel appears for a second and nothing happens.
I love Rune but I can't use it PLEASE HELP!! :? :?
johnberg
Postby johnberg » 29 Oct 2016, 11:14
@Surfninja
Sorry I did not see your answer because it jumped to page 2 :oops:
What do you mean with set username/password when mount the filesystem?
I can't find any options in Rune for setup userename/password
As I said before I was using Volumio and it scanned the harddrive with no problems.
Is there something I did not see perhaps?
My harddisk is properly mounted with a green sign as /dev/sda1
What am I doing wrong
johnberg
Postby hondagx35 » 29 Oct 2016, 17:02
Postby johnberg » 29 Oct 2016, 20:47
I use my old RPI 1 for only music.
My HDD is untouched, as far as I know formatted to ntfs
Before succesfully used with Volumio ;)
johnberg
Postby johnberg » 29 Oct 2016, 21:02
When I give the command in Putty as you show I get the answer "Elements"
Yeah, thats my baby who is not recognized!!
Sorry I think it is recognized but Rune is refusing to scan the awfull lot of files.
johnberg
Postby hondagx35 » 29 Oct 2016, 22:16
Postby johnberg » 30 Oct 2016, 13:19
Yes there are also a lot of nonmusic files on my hdd.
Is coverart a problem .jpeg and .png? I don't hope so.
How do I create an .mpdignore file? Just rename a .txt file with no content?
I hope that the developer is also working on this problem and I hope that the next update will solve this issue. :D
I think I gonna try first now with some musicfiles on a simple usb-stick.
I also see now that I can't reach the hdd on Rune with the filebrowser on my Ipad (SMB).
Upnp and dlna is enabled.
I love Rune because it is putting the files in a Spotify playlist in the playlist of Rune itself. Volumio 1.55 is just playing the whole list and you can only listen everything or next - next - next........this is very boring.
I think Rune even can make a mix of Spotify and hdd tracks in the playlist.
How do I make a command in Putty to see the musicfikes on my hdd?
johnberg
Postby surfninja » 02 Nov 2016, 17:29
John, Frank provided some tidbits of info. if you click on the .mpdignore link, you should get an idea how the file is used.
while I don't have any problems with rune and my NAS, my guess you create this file and add lines describing the files you want to ignore.
*.doc
*.docx
*.xls
*.xlsx
*.ppt
*.asm
*.drw
My guess based on your questions, you will want to use nano (again google is your friend) text editor. I use vi or ed but don't recommend it for you.
surfninja
Postby johnberg » 04 Nov 2016, 11:03
@Surfninja,
Can you give me a simple step by step guide to add lines for ignoring files while using Nano text editor.
I am not Inux expert and even don't where to begin.
Can I also use Putty to add these lines?
I am wondering why NAS users have not problem at all with Rune when building the MPD library.
As I wrote before Volumio is working perfect with my harddisk and we should work on it that Rune can do the same, it is very essential! :shock:
Please any help is welcome :?
johnberg
