Can not see UI / new install
Postby jim-rune » 05 Jan 2016, 20:35
Hello all,
I'm new. Been trying to set up on a raspberry pi.
Downloaded to SD card, pi boots to login prompt (as expected)
Can't seem to get to the UI. Using arp-scan, determined ip is 192.168.1.100.
Using Firefox, when ip is pasted to the address bar, get password dialog box...
A Username and password are being requested by http://192.168.1.100.
The site says: "Enable Mode"
User Name: rune
Password: *****
Tired: rune/audio, rune/Audio, root/rune and others.
Searched thru http://www.runeaudio.com/documentation/ and forums but couldn't find the issue.
It must be simple, but, I can't seem to figure it out.
Hints? Doc/Forum links?
Thanks,
Jim
jim-rune
Re: Can not see UI / new install
Postby ACX » 05 Jan 2016, 22:25
Hi jim-rune, are you sure you are pointing your browser to the right IP address? If you have access via terminal to your Rpi, log in with the standard credentials (root/rune) and check the IP from there with the "ifconfig" command.
Postby jim-rune » 06 Jan 2016, 17:03
Thanks ACX.
Good cross check. I wasn't using the right IP. The connection might be the problem. I tried a few more things (below) but, I'm out of ideas.
The ifconfig output dosn't look normal as compared to Linux mint/debian/bash...
It dosn't have any inet sections. The ether section looks more like a hardware address than an IP.
(BTW how to I set up ssh? It would be nice to be able to cut and paste output)
The rune install was with RuneOs: 0.3-beta (build 20141029)
On another SD card, the pi boots to Raspbian Jessie. From that install it gets full network and internet connectivity.
jim-rune
Postby jim-rune » 10 Jan 2016, 18:05
Does hardware matter?
Wondering if the version of the pi matters? I have a model B with 512.
jim-rune
