Can't access GUI or samba
Postby james_b » 20 Jul 2016, 21:02
I've been running Rune on a Pi 2 for several months without many problems, but now I can't access the GUI through Chrome (using runeaudio.local or the IP) or connect via smb in the terminal/ finder. Powering off the Pi at the power source is the only step I can think of to remedy this but it isn't working.
Runeaudio appears as a connected device in my router's settings which leads me to think that the Pi install is working, but I'm not sure what else could be the problem. What steps should I take to fix this?
Thanks!
(I should add that rune stopped working shortly (but not immediately) after disconnecting all cables while moving to a new rack. May not be relevant.)
james_b
Re: Can't access GUI or samba
Postby james_b » 20 Jul 2016, 22:00
After an hour or so of unplugging, restarting etc I'm back in action, but none the wiser as to what the problem was.
My setup is like this:
USB HDD > Powered USB hub > RP 2 using a Realtek USB adapter > Denon DA-300-USB
I have little faith in the USB hub (a cheap thing I had lying around) and the wlan adapter isn't anything special. But the Pi and the Denon should both be good. The USB cables I'm using could be at fault, they were found in the back of the drawer somewhere - but is this likely to be the problem?
Debug info is here if anyone can make any sense of it - http://pastebin.com/5Euu0rh4
james_b
Postby james_b » 20 Jul 2016, 23:43
Sometime later I can't access runeaudio.local yet again.
The album I started about 25 minutes ago is still playing without a problem. Attempts to ping the IP results in "ping: sendto: Host is down".
Presumably if the player is working but the network connection is down the usb wlan adapter is likely to be at fault? Though I can't quite understand why my router admin page would still think runeaudio is connected. I'm not having any trouble connecting to the router with my laptop or phone.
james_b
Postby james_b » 24 Jul 2016, 11:50
Still experiencing this problem despite switching to a Pi 3 - still connected according to the router, all lights functioning on the PI but unable to connect through the browser, finder or terminal. The only consistent component is the DAC and maybe the SD card
Is there anyone out there who could assist me with this? Having to unplug the power every time I want to listen to music is really taking the fun out of this.
james_b
Postby hondagx35 » 24 Jul 2016, 23:26
Postby james_b » 25 Jul 2016, 01:46
james_b
Users browsing this forum: Bing [Bot] and 44 guests
