Hi everybody,
I installed the last version of Rune Audio on a Cubieboard 3 (Cubietruck) today.
I plugged the Cubie on my network with the card in and switched it on. I then tried to:
1) connect to http://runeaudio.local/ and it did not work;
2) Connect to the device IP and it did not work either;
3) SSH the device and it did not work;
4) Check my router and found the device on the network map, also check my port routing and nothing special there;
5) Ping the device IP and it actually worked.
Can anyone tell me please what I am missing? I basically see the device on my network, I can ping it but that's it. It is odd.
Thanks in advance.
