Can't connecting ...
Postby Fred » 19 Dec 2014, 11:26
Hello everybody,
I have a Raspberry Pi B+. For my tests, I use a USB flash drive Fat32, and small speakers on the audio output of the Raspberry.
On a first SD card, I already have Volumio and it works perfectly.
I've just installed Runeaudio on a second SD card (I would like to try it ... because it read somewhere that it works with ExFat disk ... but it's another story).
The material configuration is exactly the same, but I can't even start using Runeaudio because the web RuneUi is in a infinite loop (the two arrows and the word "connecting"). If I put again the SD card with Volumio, it works, if I use the SD card with Runeaudio : nothing ... :o(
Can somebody help me ?
Thanks by advance.
Fred
Re: Can't connecting ...
Postby hondagx35 » 19 Dec 2014, 14:32
Hi Fred,
is it possible for you to connect to the dev-page of runeaudio?
http://your-ip/dev (for example http://192.168.0.133/dev)
or
http://runeaudio/dev
if so, please try to update your image:
how-to-update-the-runeui-via-git-t547.html
Postby Fred » 19 Dec 2014, 15:39
Hello Frank,
First of all, thank's for your quick reply.
Unfortunately, I can't connect to the /dev page ...
I can see "development settings" and other things in the background of my web page, but the two rotating arrows are still in front, trying to connect ...
Few minutes after : Finally I found a solution !!!!! I just change my web browser from Safari to Firefox (I use an old mac mini on OS X 10.5.8). Now I can use it ! Youhouuuu ! I can go further in the discovery of Runeaudio !
Sorry if my problem was so stupid ... But may be it can be interesting for the developers :oops:
Thank's again to Frank.
Fred.
Fred
Postby hondagx35 » 19 Dec 2014, 15:49
Hi Fred,
can you ssh to your pi?
If so please try to update manually:
cd /srv/http && git pull
frank
Postby dwijtsma » 19 Dec 2014, 22:48
There are more problems with specific browsers. Latest Firefox on Windows 7 has issues loading the library tab.
dwijtsma
Postby hondagx35 » 19 Dec 2014, 23:10
Hi dwijtsma,
is your installation up to date?
If not please update via git pull as mentioned many times on the forum.
I'm using Firefox 34.0.5 on Windows7 without problems.
