Can't get started! help!
Postby McFly » 25 Mar 2017, 20:24
HI Everyone!
Looking for help now...
Just got my pi3 with hifiberry digi+ hat. Also, WD PiDrive 1TB HDD to be added to the equation later on. All excited, I followed all instructions (with win32diskimager) to write image file on my sd card (4gb kingston, FAT32) and get the thing going. As I plug the card in and put the juice...nothing. Screen is dead blank. Nothing.
- added this line in config : device_tree_overlay=hifiberry-digi
- red light steady
- green light slowly blinking
- PIDrive 3A PSU
I'm not a proficient programmer, more of a DIYer / audio enthusiast
I installed OS on sd cards before...but now, I have no clues!
Any issues with img files known?
McFly
Re: Can't get started! help!
Postby hondagx35 » 26 Mar 2017, 12:10
Hi McFly,
i would try to get it working without the hifiberry card and hdd first.
You also can try image.
Postby McFly » 26 Mar 2017, 22:59
thanks!
I tried the image you refer to, without success. I will now try without the digi+ and the HDD. À suivre...
McFly
Postby McFly » 27 Mar 2017, 22:12
Just tried with a new SD card, pi3 alone with hdmi and a monitor plugged in the DVI port. The same blank screen, with some flickering every 5-6 seconds. Could it be anything to do with config file, hdmi modes or something?
McFly
** FIXED! ** Re: Can't get started! help!
Postby McFly » 28 Mar 2017, 00:09
Finally works!
After some search about display options, modified/enabled those lines in the config file :
hdmi_drive= 1
hdmi_group=2
hdmi_mode=35
McFly
Postby hondagx35 » 28 Mar 2017, 06:10
Hi McFly,
great to hear that it now works for you.
So I guess you did not try the web interface before.
Rune Audio is designed manly as a headless player (remote web Interface).
The HDMI output is normaly not the main interface.
If you like to use the HDMI port with a monitor and mouse attached you also need to enable the cursor.
Please search the forum if this is needed.
Postby McFly » 28 Mar 2017, 22:15
Thanks, I did not know I could use a mouse and a screen! Using it headless so far. Works perfectly
McFly
