Can't mount SMB/CIFS Share from the UI (solved)
Postby EddieA » 20 Mar 2017, 19:20
EddieA
Re: Can't mount SMB/CIFS Share from the UI
Postby EddieA » 23 Mar 2017, 01:04
OK, after a load of Google-fu and comparing mount options between a command line CIFS mount and a Rune UI mount to a different server from my file server it turned out that I had to add an Advanced option, mount flags: domain=
I'm guessing that it's because my new file server is running a Samba Domain Controller.
Cheers.
EddieA
Postby EddieA » 25 May 2017, 21:16
EddieA
Postby hondagx35 » 25 May 2017, 21:57
Postby EddieA » 26 May 2017, 21:15
OK, it's the "sec=ntlm" parameter that causes this.
If I enter the exact command as Rune in the command line, I get the "Permission denied" error. If I drop the "sec=ntlm" parameter, or change it to "sec=ntlmssp", then the mount is successful.
I tried to add "sec=ntlmssp" to the Advanced options, but that just causes both versions to be presented on the command line, which still fails.
Side note: When selecting Advanced options, the Mount flags box is pre-filled with "cache=none,ro", but typing anything removes those, not adds to them.
Cheers.
EddieA
Postby hondagx35 » 27 May 2017, 00:35
please try the "OS x share" it adds "nounix,sec=ntlmssp" to the options.
Postby EddieA » 28 May 2017, 00:36
Frank,
Yep, using that suggestion allows the mount from the UI. Thanks.
Cheers.
EddieA
