Change Play/Pause Button Display
Re: Change Play/Pause Button Display
Postby rern » 05 Feb 2018, 03:04
Postby gcogger » 05 Feb 2018, 13:51
gcogger
Postby rern » 15 Feb 2018, 14:33
Now you can set it to your liking in .
A new item in show/hide setting.
Postby R101 » 15 Feb 2018, 18:15
Thanks rern, that is a terrific improvement. There is a bug, though. When displayed on a 7" Android tablet, the "next" button is below the others.
Postby andfor » 16 Feb 2018, 11:29
Hi rern,
Is there a way to implement this without installing all of the UI enhancements for those of us that have modified the UI in various ways ourselves? I've had a quick look at the GIthub page, but I'm either blind or not technically-proficient enough to understand what's happening.
Many thanks for all your hard work on this and other improvements.
andfor
Postby rern » 18 Feb 2018, 03:27
Postby andfor » 18 Feb 2018, 10:30
That, good Sir, is most excellent.
You are a gentleman.
Many thanks.
andfor
Postby R101 » 18 Feb 2018, 17:18
Hi rern,
I have discovered some problems using this enhancement with my 1024x600 Android tablet. I am not sure if they are all caused by this enhancement, as I do not normally hide the top/bottom menus.
With 3 button display selected, the "next track" button floats below the other 4 when the tablet is in portrait mode. Landscape mode looks the same until the browser is refreshed, and then the top/bottom menus disappear. The top/bottom menu item in the show/hide menu is greyed out and set to hidden in landscape mode, even when ticked. Problem is that swiping to the top edge does not now make the t/b menus appear in landscape mode, or in portrait mode when the t/b menus are hidden.
The Android app behaves in the same way.
This is probably not the place to mention it, but when using the Android app with UIe there is a problem swiping left to right, as this action is already used for a function in the app.
Users browsing this forum: Baidu [Spider] and 19 guests
