Chord Mojo
Chord Mojo
Postby silvrr » 22 Mar 2016, 03:23
Chord Mojo is working nicely with the Pi 2 and 0.3 beta. 16/44.1, 24/192 and 24/96 all play without issue.
The bit rate indicator is also showing the change in bit rate each time so the Mojo is detecting the bit rate changes as each track starts.
There is a 1 second delay in playback if you change bit rates. I believe this is known issue with the Mojo.
silvrr
Re: Chord Mojo
Postby silvrr » 24 Mar 2016, 02:24
silvrr
Re: Chord Mojo
Postby PeteB » 24 Mar 2016, 05:51
Very nice! (I am starting to have second thoughts about my rats-nest of wires)
Re: Chord Mojo
Postby silvrr » 24 Mar 2016, 11:04
Yeah, power in and audio out is a pretty simple setup. Much simpler than my normal setup with multiple power cords and interconnects.
silvrr
Re: Chord Mojo
Postby dunghnguyen » 29 Mar 2016, 06:55
You just pluged it in the usb port then it was configurated automatically? What is the MPD option you have seen and selected ?
Have you checked playing DSD from Rune?
dunghnguyen
Re: Chord Mojo
Postby silvrr » 29 Mar 2016, 12:03
Yes it was plug and play. It played right away and "mojo" showed up in the MPD pull down.
Sorry, didn't try and DSD content.
silvrr
Re: Chord Mojo
Postby ttarpd » 19 May 2016, 12:47
ttarpd
Re: Chord Mojo
Postby dunghnguyen » 19 May 2016, 12:58
@ttarpd: I asked you nearly 3 weeks ago that I have not seen the reply. I was shared by others that it played well so I went up with the SMSL M8 here as it played perfectly with Pi 2 viewtopic.php?t=3598
dunghnguyen
Re: Chord Mojo
Postby ttarpd » 19 May 2016, 13:32
Sorry - I only joined the forum in the last couple of days and saw this unanswered question. Perhaps someone else will benefit from the answer.
Hope you enjoy the SMSL M8! :D
ttarpd
Re: Chord Mojo
Postby dunghnguyen » 19 May 2016, 13:46
No issue bro ! Hv a nice day ;)
dunghnguyen
Return to Compatibility list
