Clicks listening to Spotify
Postby Jck » 21 Nov 2014, 17:52
Hello everybody,
I searched the forum but it seems that no one reported this problem: I'm experiencing a lot of clicks while listening to Spotify using RuneAudio on a Raspberry PI B+ connected to my AV receiver through HDMI.
Everything else (Webradio and FLAC from USB and NAS) is working great.
There is something I can try to do to solve the problem?
Thanks in advance :) .
Jck
Re: Clicks listening to Spotify
Postby hondagx35 » 21 Nov 2014, 19:00
Postby Jck » 25 Nov 2014, 09:41
Thanks for your answer.
I tried a couple of 320kbits webradio and they worked fine after a few "jumps" at the very beginning. I don't think this could be a connection problem because I can listen to Spotify smoothly from mobile, PC and from the Spotify app on my AVR (with one of the ugliest UI ever seen...). Beside, I usually stream 1080p video + 5.1 audio from Netflix.
I also tried to mess with the spop.conf file, setting high_bitrate = false to request 160kbit audio, but clicks are still here.
Last test has been to run spop directly from the command line, but still no luck.
spopd.log file reports several "[ap:4210] ChannelError(0, 1, playlist)" during playback, but I have not been able to find informations about them.
Any thoughts?
Thanks!
Jck
Postby hondagx35 » 25 Nov 2014, 10:42
you can experiment with the settings in spopd.conf.
# Cache path -- the location where Spotify will write cache files. This cache
# include tracks, cached browse results and coverarts. Set to empty string to
# disable cache.
Can be the same as the settings path. Defaults to
# $XDG_CACHE_HOME/spop (usually ~/.cache/spop).
#cache_path = /var/lib/spop
# Cache size, in megabytes. The default value is 0, which means 10% of disk free
# space.
#cache_size = 0
As far as i know, caching is disabled in the configfile.
Postby hondagx35 » 25 Nov 2014, 12:56
these settings work for me.
### Cache settings ###
#cache_size = 0
cache_path = /tmp/spop
settings_path = /tmp/spop
Be carefull, the cache is written to sd-card, so there may be some "wearout".
If it works for you we have to find a way to do it in memory.
Postby Jck » 26 Nov 2014, 14:28
Thanks hondagx35.
I tried several combinations: cache on, cache off, small cache, big cache, cache on an external USB drive. I also tried to increase spopd process priority, but I didn't hear any difference (i.e. still clicking).
My configuration is pretty standard... How can I be the only one with this problem?
Jck
Postby cubix » 22 Dec 2014, 23:24
Hi Jck,
Did you manage to resolve your issue? I'm experiencing similar clicks and pops when listening to Spotify tracks.
Cheers
cubix
Postby Jck » 23 Dec 2014, 08:57
Unfortunately I'm still experiencing the problem. I hope it will be solved in the next release of RuneAudio!
Jck
Postby Anda » 27 Dec 2014, 15:17
Anda
Postby Jck » 29 Dec 2014, 10:20
Thanks for the suggestion. I will give it a try, but first I have to make Spotify work again... I think I broke something trying to recompile spopd... :lol:
Jck
