Connection failed and MPD DB gets reset
Postby zarchucho » 23 Jan 2015, 07:37
I've been using MPD for a while now and recently decided to update to get Air Play and DLNA. I downloaded the most recent image, checked its checksum, and dd'ed it over. Everything seemed to work fine at first as it started to build the database (I was able to play music as it continued to scan). But once it finished, the client I was using (MPDroid) gave me an error that it couldn't connect. I tried the web interface and just got the spinning "connecting" arrows indefinitely.
I can ssh in and reboot, and then the DB disappears. I reload, and it works until it's done and then does the same thing.
I tried doing a git pull and it didn't change anything. It seems like an issue with the MPD daemon, but that always worked fine on my old install. I tried poking around the logs but couldn't find much of interest, but I can copy and paste them here if anyone thinks they would be useful.
Here's the debug info:
My setup:
Raspberry Pi w/Ethernet (model B, I think).
1.5 TB external USB HDD
Primary Client is MPDroid, but I occasionally use the web interface.
Thanks in advance.
zarchucho
