Connection & Reproduction Problems
Postby lifegoeson » 11 Dec 2015, 10:52
Hello
I'm trying to solve some issues:
My Configuration :
Raspberry P2 model B connected to the network by wi-fi dongle (random IP address )
HDD x 2 -usb 3.0- conf. raid 1- part. FAT 32 - 3 TB
Unfortunately i'm not able to connect to Runeaudio at first shot with my macbook and sometime it does'n connect at all so. , i have to close and re-open the browser ( the connection is wireless as well ). If i try to use the IP addres instead of http:// runeaudio.local i get the same result.. . My wifi network is ok . signal strengh very good.. Something about my browser ?? What do you think ??
The second point concerning the player..
The infos about flac files and cover art are showing on screen every time i create a playlist in the queue and the play starts , but... Rune Audio goes in a kind of " freeze" if i leave the macbook for a little while... If i re-open it , the files informations are blocked on first tracks and remains the same even if i go to the next song.. Sometime i cannot acces to the HDD as well..it depends..
What do you suggest me?? Could be a network connection problem?? My ext HDD ( i don't think so ..) ??
I'm getting crazy..
Thank You
lifegoeson
Re: Connection & Reproduction Problems
Postby hondagx35 » 11 Dec 2015, 12:45
Hi lifegoeson,
please first answer this questions:
- your USB hdd is connected to the Pi?
- which browser?
- did you try a different browser?
Postby lifegoeson » 11 Dec 2015, 16:39
Yes it is...is connectedby USB to the Raspberry
Browser SAFARI
no, i did not try other Browser
lifegoeson
Postby hondagx35 » 11 Dec 2015, 18:49
Postby lifegoeson » 12 Dec 2015, 11:18
Thank You Frank
I know how to use SSH
The code is for the update of RuneAudio isn't it? If i remember well once i go to the main menu of the software there is an option to allow the automatic update ... i'm not 100% sure... anyway
I think the first reasonable thing to do is switch of the automatic library rebuild ...tha't what i'll do first of all.
I'll let you know ASAP
Thank's again
Lifegooeson - Milan
lifegoeson
