Cover Display
Re: Cover Display
Postby amadeus74 » 23 Oct 2014, 11:23
OK ACX. I wait for 0.3 beta.
p.s. I've posted the debug info for my configuration with the Odac in the thread of the volume hardware control.
Bye
amadeus74
Re: Cover Display
Postby ACX » 23 Oct 2014, 14:09
Re: Cover Display
Postby amadeus74 » 23 Oct 2014, 15:00
Great thank.
amadeus74
Re: Cover Display
Postby pduerden » 08 Dec 2014, 13:13
Hi there
I hope you can help. I'm a Linux newbie but have managed to get 0.3beta for Raspberry PI installed and working. I can use the web interface and also MPDroid to control the PI remotely.
I've got to say it was all pretty straight forward and easy, thank you to all involved.
I'm having an issue with Album art in the Rune UI and MPDroid. I would like to use my local covers. I have read this thread and set MPDroid as follows
Download local cover art = <checked>
Path to music = coverart
Cover filename = <whatever you want> (I have set this to cover.jpg as per my naming convention)
My guess is the path is incorrect but I'm not sure what to set it to. My library structure is
<IP Address>/My Music/Artist Name/Album Name
It also mentions that I may need to use git pull to update PHP settings. I'm not sure if this is required or if it was included in the beta.
Are there other steps I am missing and should be following?
With regard to the RuneUI I'm not sure why it is not picking up the covers or if there is a setting I should use. It is getting some covers but they appear to be downloaded over the web.
Cheers
Phil
pduerden
Re: Cover Display
Postby rodgersan » 08 Dec 2014, 13:21
rodgersan
Re: Cover Display
Postby pduerden » 08 Dec 2014, 20:16
I couldn't get it to work so I de-installed MPDroid and re-installed. Changed the setting and now it works....thank you.
Does the MPDroid setting Album cover art listing in library work for you ? The cover art only works when I go into an Album
Phil
pduerden
Re: Cover Display
Postby rodgersan » 08 Dec 2014, 23:34
rodgersan
Re: Cover Display
Postby rodgersan » 07 Feb 2015, 14:48
rodgersan
