Crackling / pops on USB DAC
Postby betocool » 08 Oct 2016, 08:36
Hi guys,
been using RuneAudio 0.4 beta on a Raspberry Pi 3 for a few months, and I'm very happy with it. Kudos to the great job, it's a very nice interface and player.
However, sometimes I get on some tracks a bit of crack/pop noises playing FLAC files (44.1/16) over NFS/Wifi. I notice that especially while listening on headphones. Other times I don't really pay any attention. I'm using an Amanero based USB DAC, and I wonder if that may be the issue? The wifi seems to be pretty stable, haven't had any problems there.
I read somewhere something about a USB driver upgrade, but I think that was for a RPi 2/B?
Any help or comment is appreciated. Happy to provide more information if needed.
Cheers,
Albert
betocool
Re: Crackling / pops on USB DAC
Postby hondagx35 » 08 Oct 2016, 10:08
Hi Albert,
welcome to RuneAudio.
You can try to update the kernel as described .
Postby betocool » 08 Oct 2016, 14:01
thanks for your help and quick answer.
I did resize the partition and did the upgrade, as expected, that worked well.
There's still the odd crackle/pop while playing the FLAC's from the network. I'm pretty sure the digital files are ok, I rewinded to the same spot I heard the noise before and it didn't happen twice. In all fairness though, they seem to happen less than with the previous kernel.
Any log message I can have a look at if any data packets were dropped somewhere?
Cheers,
Albert
betocool
Postby betocool » 09 Oct 2016, 00:27
So, further news.
I had a look at the RuneAudio debug info. Only 28 packets lost on Wifi. Not the world.
I also had a try at increasing the buffer size and the amount of buffer being full before playing to 4096Kb and 30%.
That seems to have done the trick. Had a listen yesterday on the tracks I knew came up with faults, and they sounded all perfect. No noticeable delay on play/pause/stop either. Good stuff!
Still, is there any way I can check if any audio packets were dropped somewhere?
Cheers,
Albert
betocool
Postby hondagx35 » 09 Oct 2016, 10:26
Hi Albert,
change the mpd loglevel to verbose and check the log file
/var/log/runeaudio/mpd.log for errors.
Postby betocool » 15 Oct 2016, 03:44
I just checked the mpd.log file, there seem to be no packets dropped or anything. I still have to have a quiet dedicated listen, but I think increasing the buffer size and amount before playing helped significantly.
Thanks a lot!
Alberto
betocool
Postby IgorGIV » 22 Oct 2016, 16:44
Hi, betocool!
Had the same problem with my RPi3 and usb dac. The problem was in built-in WiFi, which has very poor performance (you can search about it and it's performance tests in internet). So i changed my connection from wifi to wired (ethernet), and it solved the problem. No more crackling / pops.
Hope it will help to you and others.
P.S. Sorry for my Eng, but my native is Russian. And i hope i was understandable.
IgorGIV
Postby truckinve » 23 Nov 2016, 12:01
truckinve
Users browsing this forum: Baidu [Spider], Bing [Bot] and 4 guests
