Creative XFi USB Works (but...)
Postby Pondidum » 07 Feb 2014, 22:02
The Creative X-Fi USB Model SB1090 works fine (tested with Raspberry Pi model B and powered USB hub.)
Is there any chance that RuneAudio could support the harware volume control on it? (tested both as software and hardware mode volume control, to no avail).
Pondidum
Re: Creative XFi USB Works (but...)
Postby ACX » 08 Feb 2014, 16:06
Hi Pondidum, if an interface offers hardware mixer control and does not require custom drivers to work under Linux, then it should work out of the box. Please type alsamixer in command line and look if volume control is available there, that's the hardware mixer.
Postby Pondidum » 08 Feb 2014, 23:47
The only item listed in there is the Power LED.
Not to worry then, thanks for the reply!
Pondidum
Return to Compatibility list
