DAC or Digi+?
DAC or Digi+?
Postby ethanc1993 » 03 Jul 2016, 22:47
I'm trying to use rune audio with a raspberry pi to play music from the pi to my speakers but no sound comes through when I try to play something so I've figured I probably need a HifiBerry DAC or Digi+ but I am not sure which to get for this purpose. I was wondering would any know which one to use? Or do I just need to configure something in the pi to get the sound working?
Thanks,
Ethan
ethanc1993
Re: DAC or Digi+?
Postby vulpespersona » 09 Jul 2016, 18:02
I found this to be true when I first installed Rune (with no prior Linux knowledge) and couldn't hear audio out of the pi headphone jack. It was frustrating. I thought the unit might be broken. After digging around, I eventually found information on this forum. You need to load Alsamixer to bring up the sound level. Instructions here:
volume-t1248.html#p7374
This should help make your unit function to play music/sound, however ultimately the stock pi audio out has much to be desired. Very bad quality (think 80's pocket radio earbuds) and you get consistent background static. I upgraded to a HifiBerry DAC and it sounds great for a relatively small price. A little bit of trouble shooting too install for a newbie (it's not plug and play, you have to change some coding to have the device come up in Rune settings - can-t-enable-hifiberry-dac-plus-or-i2s-t1250.html ) but there are plenty of resources on this forum to help guide the install. Otherwise a USB DAC would likely work as well and there are several discussions on recommended model options on the forum.
vulpespersona
Re: DAC or Digi+?
Postby ethanc1993 » 11 Jul 2016, 16:47
ethanc1993
Re: DAC or Digi+?
Postby hondagx35 » 11 Jul 2016, 17:18
