DAC PCM5102 I2S P5 32bit/384Khz Raspberry PI
Postby sepo » 25 Aug 2014, 20:59
hello there,
I have a new one dac dac pcm5102 i2s p5 32bit / 384kHz Raspberry PI
I try to make it work with runeaudio but without success. I also tried with volumio but it's the same thing. Does he need a specific driver?
thank you for the help
sepo
Re: DAC PCM5102 I2S P5 32bit/384Khz Raspberry PI
Postby ACX » 26 Aug 2014, 01:28
Hi sepo,
which version of RuneAudio did you try? the supports I2S DACs out of the box. Being your DAC based on PCM5102, it should work fine selecting the "HiFiBerry DAC" module under Settings > I²S kernel modules.
Return to Compatibility list
