Default sound volume
Postby Baltasar » 25 Apr 2015, 16:31
Hi, first let me say this is a great project and I love it !!!
So, I'm experiencing low volume even the sound is at 100% on the analog audio out from my Raspberry pi B+ comparing with the other sources on my HIFI system, to listen the raspberry at the same volume more as led as the others I have to put the amplifier at 30% (minus Db) and usually at 50% I get a average listen volume from my other sources (CD, Tunner, etc).
IS there a way of I increase the signal and setting it as the default 100% for Rune Audio?
Thanks.
Baltasar
Re: Default sound volume
Postby bevlar » 26 Apr 2015, 22:41
bevlar
Postby Baltasar » 27 Apr 2015, 01:12
Hi, I already did that, sound is at 100% / max, the problem is the max is low on my Yamaha amplifier compared with the other source, like CD player, SAT receiver, tuner, etc. So when I move from the Rune Audio to the others I have to lower the amp volume a lot, I was searching for something that modify the raspberry analog exit gain so all became even.
Baltasar
Postby bevlar » 27 Apr 2015, 07:12
I would look into an alternate DAC if i were you.
bevlar
