device not saving wifi credentials -- no connection
Postby asilker » 24 Sep 2017, 21:43
I am using an RPI b 3 with the v0.3-beta (23/03/2016) release. Currently the unit is plugged into a monitor via HDMI, and I am using a Logitech keyboard to navigate through the UI. I do not have any touchscreen devices to wire to the RPI, but with some care and extra patience I am able to navigate just fine with the keyboard.
When I get to the network page, I can find my wifi network, correctly enter my password, and navigate to the "save" button. However, when I click or press enter, the device is not saving my password and the status still stays disconnected.
I have cleaned the SD card, repartitioned etc and rewritten the image. What else can I try here?
I don't have an ethernet cable in the house, but I can order one if that's just the way things go. Thanks for the help!
asilker
Re: device not saving wifi credentials -- no connection
Postby hondagx35 » 24 Sep 2017, 23:04
Postby asilker » 28 Sep 2017, 22:28
your DHCP trick worked perfectly. Thanks!
asilker
Postby jxx2005 » 04 Oct 2017, 20:26
I tried this with my unit, but it still didn't save the wireless credentials.
I'm not running a 2, its an original B+ with a WiPi adapter for the wireless.
I might have been doing it wrong, so correct me if thats the case
1. connect via ethernet with dongle connected to USB
2. through the webUI, access network settings, set DHCP to static (with 0.0.0.0 in the ip fields), save and apply
3. set back to DHCP, save and apply
4. try to reconnect to wireless
jxx2005
Postby hondagx35 » 04 Oct 2017, 23:07
Hi jxx2005,
the image for the RP1 is very old and needs to be updated.
Read http://www.runeaudio.com/documentation/ ... /updating/ and try to update to the nightly builds.
Postby jxx2005 » 05 Oct 2017, 00:31
jxx2005
Postby jxx2005 » 05 Oct 2017, 01:48
Hey! updating to the nightly seems to have worked!
jxx2005
Postby asilker » 05 Oct 2017, 17:48
asilker
