Difficulties Getting to RuneUI
Postby sontung » 19 Jul 2017, 12:09
Hello everyone,
I recently started using Rune Audio and went through all the steps to start the OS. I successfully formatted and wrote the image file to the SD card, and booted the Pi (Pi Model B) while connected to a monitor. It went through the whole startup process and ended up at the login screen like it should.
Now here is where the problem arose; I disconnected the pi and plugged it into my WiFi through Ethernet. I also had a powered USB hub attached with a flash drive and a WiFi dongle. I powered it on and watched the flashy lights all blink on and the WiFi dongle started flashing. I then went to my computer and tried to connect to all the local music players. After several attempts, I tried the IP of the pi and it connected fine.
When I connected it too my WiFi through the dongle it said it worked and so I moved it elsewhere and to my suprise I could not connect to the device, whether through Ethernet or WiFi.
Am I missing something blindingly obvious or did I screw up??
sontung
