Dirble (null) not working?
Re: Dirble (null) not working?
Postby ktm » 05 Aug 2015, 19:40
I've got the same issue with Dirble.
I tried to gitpull and got this message
Update RuneUI
RuneUI updated successfully
error: Your local changes to the following files
would be overwritten by merge:
app/config/_os/usr/lib/systemd/system/shairport.service
app/config/defaults/shairport.service
app/coverart_ctl.php
app/libs/runeaudio.php
app/network_ctl.php
app/templates/network_wlan.php
app/templates/playback.php
app/templates/settings.php
assets/js/runeui.js
command/airplay_toggle
command/rune_PL_wrk
db/index.php
Please, commit your changes or stash them before you can merge.
Aborting
Updating 077e21a..248e6cc
I assume that there is something I need to do to make the merge work
other than going to the different screens and saving?
ktm
Postby ktm » 06 Aug 2015, 01:11
Ok, got it figured out after some searching.
Had to git reset --hard and then do the update.
I have dirble now. It still shows the null value, but
the headers and stations show up. Is my imagination,
or are the lists shorter?
ktm
Postby AndyF » 07 Aug 2015, 18:10
@ACX
- Dirble work again (some navigation glitches and "null" at library screen)
- airport works (it was my fault - I have a USB-Soundcard and shairport-config was set to hw:0,0 after changing to DEV branch)
:D :D
Thanks for your work - best Audioplayer ever!
Andy
AndyF
Postby AndyF » 13 Aug 2015, 05:11
@ACX
Category Pop/Top 40 doesn't stop loading in Dirble menu. Every other category seems to work.
Is this a Dirble or an Runeaudio-Problem?
regards, Andy
AndyF
Postby ACX » 13 Aug 2015, 15:02
Postby tobyl » 23 Aug 2015, 17:58
I'm also missing dirble....I tried to do the GIT pull, which appeared to be successful, but still spinning when I click on Dirble in the Library. I even tried the --hard reset command, though I'm not sure I did everything in the correct order - could someone give me a step by step instruction on how to update - sorry I'm not really familiar with GIT.
tobyl
tobyl
Postby hondagx35 » 23 Aug 2015, 20:55
Postby AndyF » 30 Aug 2015, 18:36
Hallo Frank,
Top40-Problem is still present - endless loading ....
regards,
Andy
AndyF
Postby blooper65 » 05 Sep 2015, 13:31
When can we expect a solution for not working Dirble? It seems that there is not much going on at Rune Audio. :cry:
blooper65
Postby elmarhe » 08 Sep 2015, 14:16
Switching to the nightly builds (installed yesterday) did it for me.
Well - it still says Dirble(Null), but apart from that everything is fine.
Thanks guys!
elmarhe
