Echo in replay
Echo in replay
Postby RedAdmiral » 12 Jan 2016, 23:24
I experienced a bug with the audio buffering: Everytime I started a new song there was an echo of about half a second to a second. Pausing the song and restarting it helped but was annoying. When I disabled the buffer before play the problem was gone.
RedAdmiral
Re: Echo in replay
Postby ACX » 12 Jan 2016, 23:52
Hi RedAdmiral, which device are you using? Which DAC? Where are you playing the music from? Without this basic information it's impossible to debug.
Re: Echo in replay
Postby omrison » 19 Apr 2020, 23:00
i face the same issue on a raspberry pi.
it started just now ()was working quite good.
omrison
Re: Echo in replay
Postby Taff » 29 Jul 2020, 20:09
same problem here on RPI. Using HDMI audio and music stored on the SD card
As said, turning off the buffer cures the echo.
edit.
Turning off the buffer does NOT cure the echo. it just makes it so fast that it now causes a phase change in the audio, making a slightly hollow sound to the audio.
Taff
