Electronic Distortion With Airplay
Postby piercer » 22 Sep 2014, 10:06
I am using a respberry Pi B with Rune Audio 3 alpha
I am able to play music cleanly from an attached NFS share, but when I try to play music from my wife's computer over Airplay it comes out all distorted in a weird electronic way, not white noise but electronically jumbled.
I have submitted a githib bug report, but was wondering if this was a common issue with an already know solution
Conrad
piercer
Re: Electronic Distortion With Airplay
Postby tret » 05 Nov 2015, 20:16
Bump. I have the same issue w/ a USB DAC. Library playback sounds great, Airplay playback is distorted and robotic sounding. I've had to switch to Volumio as a workaround as Airplay playback works fine there.
Raspberry Pi 2 w/ RuneAudio_rpi2_0.3-beta_20150304_2GB image
Arcam irDAC via USB
tret
Postby tret » 05 Nov 2015, 20:28
It looks like there have been other reports of this with no resolution.
song-distorted-with-conv-usb-aes-t1049.html#p6212
I tried some of the suggestions in this thread with no luck.
tret
Postby tret » 02 Dec 2015, 23:35
Bump, still no fix.
tret
Postby tret » 16 Jan 2016, 06:08
Found a solution and documented it here
tret
Users browsing this forum: Google [Bot] and 14 guests
