Enable Hardware volume control
Postby doxyq3 » 22 Sep 2014, 21:08
When in software volume mode, volume will vary and all formats 16bit & 24bit - 44k-192k files play fine.
Hardware volume mode is the problem, with no volume control and 24bit 192k files stuttering.
Typing aplay -l shows:
card 0: ALSA [bcm2835 ALSA], device 0 bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1 bcm2835 ALSA [bcm2835 IEC958/HDMI]
subdevices: 1/1
card 1: Dragonfly [Audioquest Dragonfly], device 0: Usb Audio [Usb Audio]
I'm sorry but I'm totally ignorant with Linux. I don't understand a lot of the posts that show editing some sort of config file.
Thank you for bearing with me.
doxyq3
Re: Enable Hardware volume control
Postby cmh714 » 23 Sep 2014, 19:03
The DragonFly doesnt have a HW volume control so thats out for you. And Software volume lessens the quality of the music, so I personally dont use it either.
As for the file stuttering, you need to fine my post on it :) and you can fix it rather easily......
