ERROR: Failed to decode MPC Error (Solved)
Postby irishwill2008 » 07 Mar 2018, 14:14
Hey guys,
I noticed that if i try to add a stream i sometimes get "ERROR: Failed to decode - followed by URL of stream". Weird thing is.. If i replace spaces with %20, the stream works a charm. Any idea why this may be? How come some streams that dont have %20 for space works fine?
Example:
http://streamsite.com/tracks/rihanna - work.mp3 // Doesnt work
http://streamsite.com/tracks/james blunt - beautiful.mp3 //Works
BUT
http://streamsite.com/tracks/rihanna - work.mp3 will work if entered like: http://streamsite.com/tracks/rihanna%20-%20work.mp3
Please note that these examples are not working, i just made up the urls to demonstrate my issue.
irishwill2008
Re: ERROR: Failed to decode MPC Error
Postby hondagx35 » 07 Mar 2018, 18:04
Hi Will,
i have no idea what you are talking about.
Where and how do you add the streams?
Where do you get the errors?
Postby irishwill2008 » 08 Mar 2018, 11:53
I create a playlist and i then go into the /playlists directory and open the m3u. From there, i then add mp3 stream URLs into the file. So when i load the playlist via GUI (Runeaudio) they load into the queue and play! Thing is, sometimes they dont play unless i make sure the urls i enter in the m3u has %20 instead of plain space. Another way would be to add the track via webradio section. Give it a name, enter the url and i get the same issue!
Hope this helps.
Cheers.
irishwill2008
Postby irishwill2008 » 09 Mar 2018, 16:30
irishwill2008
Postby hondagx35 » 09 Mar 2018, 16:40
Hi Will,
stream URLs have to be encoded (spaces replaced by %20).
URLs are not allowed to have spaces!
Postby irishwill2008 » 09 Mar 2018, 17:42
Makes sense frank haha! Cheers pal
Will.
irishwill2008
Users browsing this forum: No registered users and 54 guests
