External USB-SATA SSD Enclosure Issue
Postby bb3ii » 01 Apr 2015, 01:00
Good Day Gents!
Attempting to use a Nexstar CX USB to SATA external HD enclosure as it has an external power port. Intel 240GB 520 Series SSD, 5V supplied via Paul Pang regulator via 12V battery (I know, overkill). Setup works fine in Winblows 7, 8, 2012.
When same setup is connected to RPi B+, Rune pops up the USB drive connected but it does not mount...total Linux noob here...
[ 602.130838] usb 1-1.2: USB disconnect, device number 4
[ 612.097246] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 612.200817] usb 1-1.3: New USB device found, idVendor=04fc, idProduct=0c25
[ 612.200853] usb 1-1.3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 612.200874] usb 1-1.3: Product: USB to Serial-ATA bridge
[ 612.200896] usb 1-1.3: Manufacturer: Sunplus Technology Inc.
[ 612.200916] usb 1-1.3: SerialNumber: INTEL SSDSCVCV205303DL240CGN
[ 612.209087] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[ 612.210234] scsi1 : usb-storage 1-1.3:1.0
[ 613.211704] scsi 1:0:0:0: Direct-Access INTEL SS DSC2CW240A3 PQ: 0 ANSI: 2
[ 613.215819] sd 1:0:0:0: [sda] 468862128 512-byte logical blocks: (240 GB/223 GiB)
[ 613.218298] sd 1:0:0:0: [sda] Write Protect is off
[ 613.218344] sd 1:0:0:0: [sda] Mode Sense: 38 00 00 00
[ 613.221196] sd 1:0:0:0: [sda] No Caching mode page found
[ 613.221236] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 613.227770] sd 1:0:0:0: [sda] No Caching mode page found
[ 613.227812] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 613.228759] sda: sda1
[ 613.236044] sd 1:0:0:0: [sda] No Caching mode page found
[ 613.236114] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 613.236145] sd 1:0:0:0: [sda] Attached SCSI disk
Looks like it is identified, but something is not working here. Any ideas??
Thanks...bb3ii
bb3ii
Re: External USB-SATA SSD Enclosure Issue
Postby mashman » 01 Apr 2015, 11:48
Have a look here at my previous post on the matter of USB power...
usb-hdd-power-consumption-t932.html
mm
mashman
Postby bb3ii » 02 Apr 2015, 18:30
I had read that post and did implement the suggestions...to no avail. The enclosure is not drawing any power from the port as the power leads in the USB cable have been cut to ensure the external power supply is utilized.
Interestingly enough, this setup works flawlessly on the Pi2 with the latest Rune build I could find. B+ doesn't like it though...
bb3ii
Postby hondagx35 » 02 Apr 2015, 20:40
Hi bb3ii,
what filesystem is on your hdd?
If it is ExFAT then take a look
