by mp29k » 06 Jan 2015, 07:55
I worked this out, silly question. The database update takes a long time (still running), but I am seeing the database gradually grow.
In beta 0.3 for the BBB, will the issue of the long DB update be resolved? I had manually configured an MPD server on this board before, and there was no issue with the database load (but I had other issues), so I am not sure the issue with Rune in taking long to load ALAC databases.
Second question:
I am having an issue when I am playing a song, and I select another and pick "Add and Play" it crashes the server.
Symptom: Select new album or song, and either Add and play, or clear add and play, the existing song stops, and the new one shows as "added" through the popup, but it doesn't appear on the playlist, and I cannot start the existing songs in the playlist either, only solution is to reboot the BBB and start over. Any thoughts?
