File storage
File storage
Postby barfkoswil » 18 Oct 2016, 11:46
Hi, i am about to complete my own project using the pi as a dedicated music system. Rather than streaming my music to the pi i am intending to play music from physical storage but have read that usb storage gives poor results. Can anyone advise me please before i make a poor purchase and waste my money?
Gratefully
barfkoswil
barfkoswil
Re: File storage
Postby hondagx35 » 18 Oct 2016, 16:13
Re: File storage
Postby barfkoswil » 18 Oct 2016, 22:35
Thanks again Frank for your help.
If i use the higher power 65w power supply do you think it would be enough to power the, pi, amp and screen? I am assuming you run the SSD from its own power supply?
Thanks in adavance.
Bryan
barfkoswil
Re: File storage
Postby Screwdriver » 18 Oct 2016, 23:44
When I first installed Rune I used a Seagate USB powered HD connected to the Pi3 with my USB Dragonfly Black DAC and had zero issues with any file, including 24/192 FLAC's. Bandwidth shouldn't be an issue. And neither was power with my setup.
Screwdriver
Re: File storage
Postby surfninja » 19 Oct 2016, 19:13
Hey Barf,
I don't think you will have any problems with network attached storage or an USB connected hard drive. I've done both without any problems.
My usb harddrive is powered. You probably don't want to power the hard drive from your raspberry pi but provide separate power.
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Re: File storage
Postby barfkoswil » 20 Oct 2016, 00:26
thanks to all for the advice which has been really helpful and i now feel able to proceed. when i finish ill let you know how it worked out. Funnily enough the system i am attempting to emulate is the Brenan JB7 / B2, i have just been on the web site and notice that at the heart of their machines is a good old PI! of course where they vary is that Brenans have a much heftier price tag.
Bryan
barfkoswil
Re: File storage
Postby Kakaomonster » 24 Nov 2016, 05:22
Hi together,
at the moment I test it only with USB sticks
8 GB - full and work perfect and fast
16 GB - the same
64 GB - NOT full, only half but the same
2 TB - only 4% in use, but the system is very slow and sometimes RuneAudio is hanging up. I can wait some minutes till it come back or power of, 2 TB stick put off and start again.
I don't know is this a stick problem (usb2) or not, but the stick works on my windows systems and my iMac perfect.
I hope this infos are helpfuly,
Regards, Kakaomonster - Ralf
Kakaomonster
Return to Hi-Fi systems
