File types not supported
Re: File types not supported
Postby rastus » 21 May 2016, 11:39
rastus
Postby PeteB » 21 May 2016, 11:40
@rastus, yes, and I did buy the transformer version for that very reason, :D
However, I suspect most people don't, and also, according to posts on the HiFiBerry forum, their implementation leaves something to be desired. They sometimes recommend shorting across the transformer, which leads me to believe they know there is a potential problem.
edit:
I guess I do need the 12-steps, LOL
Postby rastus » 21 May 2016, 11:50
rastus
Postby foxint » 21 May 2016, 11:52
Hi Guys
Thank you....my Digi+ is the transformer version - they told me this was good.
This is what I have observed: Playing the same file
Using Digi+/Rune a 44.1bit flac file shows as 44.1 on the DAC - good sound
Using Digi+/Rune a 96.0 bit flac file shows as 96.0 on the DAC - bad sound
Using Digi+/Rune a 192.0 bit flac file shows as no signal on the DAC - no sound
Using Media Monkey a 44.1bit flac file shows as 44.1 on the DAC - good sound
Using Media Monkey a 96.0 bit flac file shows as 44.1 on the DAC - good sound
Using Media Monkey a 192.0 bit flac file shows as 44.1 on the DAC - good sound
Well I am totally confused.... I have Realteck HD Audio and even when I change the bit rate it nothing happens.....I have ticked all the boxes: 44.1/44/96/192
To my way of understanding....the DAC is working....but why is nothing over 90 any good. Plus why is my MM only showing 44.1Hz. I am going to have to ask MM.
Does this shed any light on the issue?
D
foxint
Postby hondagx35 » 21 May 2016, 12:49
Postby PeteB » 21 May 2016, 13:37
@Frank: Ok got it. It was too early here, I wrote that before I was properly caffeinated... :oops:
Postby rastus » 21 May 2016, 14:15
rastus
Postby hondagx35 » 21 May 2016, 14:25
Who is Santa Claus?
Postby rastus » 21 May 2016, 14:43
rastus
Postby hondagx35 » 21 May 2016, 17:29
