finding hard drive mount windows 10
Postby Tedo1960 » 11 Mar 2016, 18:10
Good afternoon,
I cant seem to get my hard drive on my PC to mount on my pi powered, touch screen set up.
I have shared my Music folder and re set the security on it to allow sharing. I have tried this address for the folder "\\Desktop-ulc1nn6\pcmusic" which is the network path that appears in the properties for the folder. I have tried this "C:\Users\tedo1\Music" which is the location found under general.
I have tried adding passwords and removing them.
I'm buggered if I know whats going on.
Ideas please.
Ted
Tedo1960
Re: finding hard drive mount windows 10
Postby utschu » 11 Mar 2016, 18:50
Perhaps it would be easier to use a more easy path for the first step, like C:\music.
I can imagine that for a Windows system folder like Desktop it's quite hard to start with.
Good luck.
utschu
Postby Tedo1960 » 11 Mar 2016, 19:17
I did try that a couple of days ago but still no joy. Thanks for the thought though,
Ted
Tedo1960
Postby PeteB » 11 Mar 2016, 20:55
Make sure you have just the actual name of the share as seen on the network, not the full path in Windows 10. Normally in Windows the name you give to a shared folder is whatever you happened to name it at the time you set up the share. That's the name you have to use in RuneAudio.
I don't have access to Windows 10 right now, but - if I have a directory like C:\something\somethingelse\Music and I happen to call it "Petesmusic" when I share it on the network, then "Petesmusic" is what I have to enter in
MENU > Sources > Add New Mount > Remote directory
Not the path to Petesmusic, just "Petesmusic"
(plus select SMB/CIFS if this is a Windows share, AND the correct IP address of the host computer etc.)
Postby Tedo1960 » 12 Mar 2016, 08:01
HI, thanks for your help. I created a new share called PCMUSIC and checked ip address using FING on ipad. Also checked access to folder using file browser on ipad and shares are visible to it. file browser seems to require a password to access the PC so added that to PC log in and changed details in rune mount dialogue but all to no avail. rune just wont see the share. ONe thing i did notice file browser on ipad was that the PC took a while to appear, much slower than the other devices shown on the network (rune and router).
not sure if this helps but here is error message;
Usage: mount [-lhV] mount -a [options] mount [options] [--source] | [--target] mount [options] mount [] Options: -a, --all mount all filesystems mentioned in fstab -c, --no-canonicalize don't canonicalize paths -f, --fake dry run; skip the mount(2) syscall -F, --fork fork off for each device (use with -a) -T, --fstab alternative file to /etc/fstab -h, --help display this help text and exit -i, --internal-only don't call the mount. helpers -l, --show-labels lists all mounts with LABELs -n, --no-mtab don't write to /etc/mtab -o, --options comma-separated list of mount options -O, --test-opts limit the set of filesystems (use with -a) -r, --read-only mount the filesystem read-only (same as -o ro) -t, --types limit the set of filesystem types --source explicitly specifies source (path, label, uuid) --target explicitly specifies mountpoint -v, --verbose say what is being done -V, --version display version information and exit -w, --rw, --read-write mount the filesystem read-write (default) -h, --help display this help and exit -V, --version output version information and exit Source: -L, --label synonym for LABEL= -U, --uuid synonym for UUID= LABEL= specifies device by filesystem label UUID= specifies device by filesystem UUID PARTLABEL= specifies device by partition label PARTUUID= specifies device by partition UUID specifies device by path mountpoint for bind mounts (see --bind/rbind) regular file for loopdev setup Operations: -B, --bind mount a subtree somewhere else (same as -o bind) -M, --move move a subtree to some other place -R, --rbind mount a subtree and all submounts somewhere else --make-shared mark a subtree as shared --make-slave mark a subtree as slave --make-private mark a subtree as private --make-unbindable mark a subtree as unbindable --make-rshared recursively mark a whole subtree as shared --make-rslave recursively mark a whole subtree as slave --make-rprivate recursively mark a whole subtree as private --make-runbindable recursively mark a whole subtree as unbindable For more details see mount(8).
thanks again
Tedo1960
Postby PeteB » 12 Mar 2016, 08:28
Postby Tedo1960 » 13 Mar 2016, 18:56
Thanks for the help Pete, I have tried with and without password set to try and find out the issue. the settings I have are
Source name PcLibrary
Fileshare protocol SMB/CIFS
ip address as checked using FING on ipad 192.168.1.153
remote directory tedstunes (as set when setting up share)
Guest access on (to avoid need for password)
error message is;
mount error(13): Permission denied Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
Ted
Tedo1960
Postby hondagx35 » 13 Mar 2016, 20:00
Hi all,
next week i'll try to get access to a Windows 10 machine.
It should not be that hard to connect to a shared folder on it.
I'll report here after testing.
Postby PeteB » 13 Mar 2016, 20:15
Users browsing this forum: Baidu [Spider] and 30 guests
