FLAC compression
FLAC compression
Postby Fif91 » 06 Aug 2017, 12:56
Hello
I have a raspberry pi 3, used as hifi player.
I will archive all my 300-400 CDs in FLAC files, to be played on.
I discovered the FLAC file compression can range from 0 (no compression) to 8 (high compression); from this value depends the file size.
I think more compressed the files are, more power the raspberry pi will used to. Are you agree ?
My question : what is the best compression to put on the FLAC, to be read smoothly from raspberry pi 3 ?
A 2Tb drive will store the audio files.
Fif91
Re: FLAC compression
Postby Stephane » 06 Aug 2017, 16:51
Try to encode a file with 0 compression and the same with 8 then play them, login thru ssh and use the top command to see how it behaves.
My guess is that with a 4 cores CPU you won't have any trouble with the maximum compression.
Stephane
Postby hondagx35 » 06 Aug 2017, 17:40
Postby music » 22 Oct 2017, 17:38
music
