Flac in 176.4Hz
Flac in 176.4Hz
Postby mmdan » 28 Mar 2016, 17:05
I am using raspberry pi2, when I play file in flac 176.4 Hz is silent. Just want to know is not support the flac format in 176.4 Hz?
mmdan
Re: Flac in 176.4Hz
Postby PeteB » 28 Mar 2016, 18:07
RuneAudio does play that sampling rate, but depending on the rest of your gear (type of DAC etc.), you may have issues with clean playback. 176.4 is basically 4x 44.1, and I have played test tones at that frequency just this past weekend.
Here is an example you can download and test, it is a small file, so you have to put RuneAudio on "Repeat" in the Play screen for a fair test:
Beyond that, you have to provide some information about the kind of DAC you are using, USB or I2S, etc., to get more help.
Re: Flac in 176.4Hz
Postby mmdan » 29 Mar 2016, 15:14
Sorry, I am talking about flac format not wav.
By the way, I tried the file format in aiff is OK.
mmdan
Re: Flac in 176.4Hz
Postby hondagx35 » 29 Mar 2016, 15:28
