Flash Rune OS on nand
Cubietruck related support
Postby LC31 » 27 May 2015, 17:13
Dear all,
I have been the proud owner of a Cubietruck for a while now, but I am relatively new in the Linux world. So far I managed to install Lubuntu/Android on nand and had fun with it just for the sake of it. However I had no real use for my Cubie until I found Rune OS.
My question is the following: is there a way, and if so how to, install Rune OS on the Cubie's nand? I managed to do it with the above-mentioned systems by using PhoenixSuit. Yet when I try to do the same with Rune OS, PhoenixSuit prompts the following message: "image file invalid".
Could you please tell me what I should do?
Best,
PS: FYI, I also downloaded Volumio and encountered the same issue.
LC31
Re: Flash Rune OS on nand
Postby hondagx35 » 27 May 2015, 21:07
Postby LC31 » 28 May 2015, 17:26
I'm gonna try that tonight, thank you for your help!
Best,
LC31
Postby codewarrior » 04 Dec 2015, 16:16
codewarrior
Postby hondagx35 » 04 Dec 2015, 17:07
Postby codewarrior » 05 Dec 2015, 03:15
codewarrior
Postby hondagx35 » 05 Dec 2015, 09:44
Hi codewarrior,
please delete or move the image files (uImage-xxxHz) from the /boot/ folder.
They are not needed and only there for experimentation purposes.
You only need the uImage file.
Postby refssasy » 22 Feb 2023, 08:04
I'm going to give it a go tonight; I really appreciate your assistance.
refssasy
Postby samevans » 12 Jan 2024, 03:51
Hi Titus, everything is good as of now. I have moved on to EMIFA accessing both SDRAM and NAND FLASH memory.
samevans
Return to Cubietruck
